The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Questions View all
button touch buttons not working
I got my phone wet. Not hing worked. So I pulled it apart and cleaned it all up because it had salt stains. Now everything works except for my buttons down the bottom on my Samsung galaxy s3. Is there anything I can do to fix it so they work again
Add a comment
Chosen Solution
I will stress that if your phone was submerged in salt water make double certain that you do an exceptional job cleaning everything or the phone wont last long at all, here is the part you need, https://www.gounlock.com/details.php?ite..., but it could also be where this part plugs into your motherboard if it's corroded so I would double check and do a good cleaning with alcohol and a toothbrush, use these cleaning methods they are for an Iphone but it shows how to stop corrosion, Repairing iPhone Liquid Damage, here is a teardown guide also for your Gallaxy, good luck. Samsung Galaxy S III Teardown
iPhone Image
Guide
Difficulty:
Difficult
1 - 2 hours
Samsung Galaxy S III Image
Guide
Difficulty:
Moderate
Add a comment
Most Helpful Answer
This could be a Hardware issue. However, let do a quick reset and see how this works out:
Go to Settings
Select Apps
Select All (Look for ALL on top menu or swipe to the right to get to ALL)
Select Google Services Framework and tap Clear Data.
Turn off (shut down) your device and turn it back on.
Test the phone to see if it will black out again.
Hardware issue:get new here
Does the phone have any physical damages?
Score 1
Add a comment
Here Is The Solution Samsung Galaxy S3 Touch Keys Not Working 100% Tested Solution
Add a comment
he everyone ijus wanna say tht my Samsung galaxy s3 back button and main button and option stooped working and I believe tht I was using my ponw when it was raining and if anyone see this plzz reply and say if it is rain or other problems and thku and have a saf eday
1 Comment:
mean"i jus wanna" nd "I was using my phone when it was ....."
by
Add a comment
Add your answer
Adrian will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 30,448
