The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Questions View all
Question about Cleaning the PS3
I was wondering if the PS3 needs to be cleaned every so often. I mean if you need to clean the inside of the computer case to get rid of dust then I believe a PS3 needs to be cleaned.
Can somebody make a guide that shows how to properly clean the PS3.
Score -1
Add a comment
Chosen Solution
Tyler, here is a perfect opportunity. You could use this guide as well as this one and clean your PS3. While you do that, create a guide with help from here for all of us to follow the next time. Thank you.
PlayStation 3 Top Cover Image
Guide
PlayStation 3 Top Cover Replacement
Difficulty:
Moderate
PlayStation 3 Rear Cover Image
Guide
PlayStation 3 Rear Cover Replacement
Difficulty:
Moderate
Score 1
Add a comment
Get a compressor or a can of compressed air. Compressor is better as the air is far more compressed. Turn on the ps3 and blow all the vents. If you've never done this, you will get a lot of dust out.
1 Comment:
WARNING!
Some compressors DO NOT have water seperaters in the line and you may blow water from the air tank into the device.
Be sure that you at least bleed the tank to allow water to escape and reduce the chances.
Although you get a much higher CFM with the compressor, your best bet is the canned air specific for PC cleaning.
by
Add a comment
Add your answer
Tyler will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 1,251
