Guides and support for various television (TV) brands and styles.
9059 Questions View all
Question Closed
The image appears just a second and then disappears
Hello, I have a AOC TV model LM 720A. The problem is that when I turn on the TV the image appears just a second and then disappears. Any help would be gratefully appreciated
1 Comment
Does the TV turn off, or does the TV stay on, just no image?
by
Add a comment
1 Answer
Most Helpful Answer
There are a number of things that may be wrong. If it happens repeatedly, then chances are that a loose connection or poor weld is becoming disconnected when the TV heats up. The motherboard in the TV is probably the culprit. If the TV is under warranty, have it repaired. Otherwise, call the manufacturer helpline and ask them how to diagnose the problem. You can also call a local TV repair shop for an idea of what is going on and what it would cost to repair.
Score 1
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 824
