continue beep sound when os loading
my laptop giving continue beep sound when operating system loading
Since you did not provide a model for your laptop I can only give you a generic answer. the continous beeping sound usually suggests a problem with a processor.
1. A failing Video card. Try an external monitor.
2. RAM, this is common Remove the ram clean it..
3. A Processor error, remove the fan and processor. Clean it and reapply thermal paste.
4. A Keyboard error. make sure that you do not have a stuck key. Try to start with a USB keyboard.
You may get a better answer if you can give us more information as for what model. Hope this helps, good luck.
Disconnect if any other external device is connected
Check by striping down your pc by taking out the each ram module one by one, if it works fine by taking one ram apart then its defiantly the Ram which is malfunctioning.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,206
Hi, does this happen continuously? Does the operating system load? Do u have windows xp, vista or ? What is the exact model no of the laptop? Write back.
by John Savio
