The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
318 Questions View all
dryer is noisy and gets very hot
When I first turn my dryer on it's quiet but after about 20 minutes it's starts to get really loud and at that time it heats up so hot that you can't touch the clothes. When it gets this hot it wrinkles the clothes so bad you can't get them out, even with an iron.
2 Comments
Thanks for the help. I will give it a try. Does the dryer getting noisy after a while have anything to do with the extreme heat or is it a seperate issue?
by
The only thing that could make that noise is the fan motor in the back. There might be a possibility that is not working right and thus the hot air not circulating properly.
by
Add a comment
1 Answer
Chosen Solution
Steve, try to completely remove the vent from the back of the dryer and run it. See if that changes the heat. After that it is possible that either your thermostat, your elements, or your high limit thermal cut-off that need to be replaced. You can check the heating elements with an ohm meter for continuity. Remove the toe panel to get to the cutoff etc. Here is a pretty good video that shows how to test it. Different washer, same principle. Hope this helps, good luck
Score 1
Add a comment
Add your answer
Steve will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 25
Past 30 Days: 65
All Time: 11,453
