What can I do to repair the fuel pump hot lead?
Fuel pump hot lead broke at top of tank. How can I repair this?
If it is just the wire that broken, you should be able to crimp a new connector on the end and remove the old broken one from the terminal of the fuel pump. It should just be tightened to the fuel pump via a nut. If it is closer to the pump, you may have broken that terminal and will have to replace the fuel pump.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 695
