Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
156 Questions View all
DSi XL water damage blinking charger light and no power on
my little sister got her DSIXL wet and the next day it stopped working and today october 15 2012 we plugged it in the charger and it starts to blink orange then its stops but we still cant figure out wat it means. So we should charge it for the rest of the night and wait to seee if we have succed
Score -1
Add a comment
Chosen Solution
Hi there Helena
I used to work for the Nintendo Service centre UK, and can tell you that water damage is not covered under warranty. there is a little white paper sticker in the battery enclosure (if you open the back case and take the battery out). if this white sticker, has red dots or lines on it, then its considered "water damage". that is what they look for.
The advice i usually give for any water damaged electronics, is remove the battery, as soon as it gets wet, and open it to let it dry.
if there is no current running through the circuits then water doesnt really affect electronics (other than physically making them wet. if you get it to dry properly, and then put the power back in, it may still work.
But im afraid in your case, you may have even charged it whilst it was still wet inside, and this causes 'short circuits' in the electronics (because water is a conductor of electricity), and this may well have 'killed' it.
My suggestion: try taking out the battery, and opening it, to get it to dry out fully, before attempting to charge it again. if its still dead, then (if you are feeling brave), look on ebay, for a DSiXL, with maybe a broken screen, and buy it for spares. chances are good that the water hasn't damaged the LCD screens, and you can use those to replace a DSi with physically broken screens.
there should be a few step by step guides on here on how to replace screens or just take it apart.
I hope this helps
Regards
Ian
Score 1
Add a comment
When my dsi xl stop working on july 30,2013 and I change the charger I charge it and the charger light blinked orange one time so I charge it for one week and it work thanks.
Add a comment
Add your answer
Helena will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,686
