0
Score
Asked
Battery model number MacBook Pro 13 inch 2010
I was wondering; how can I determine the model number of the battery used in the Macbook Pro 13" 2010? preferable without opening up my laptop..
I plan to order a new battery online (from a non apple store) but for that I need the model number.
Grtz
Ruud van der Salm
3
Score
rj713
39.1k
Answered
Here is a link to the ifixit part number of the battery and a video showing how to replace it. Good luck.
MacBook Pro 13" Unibody (Model A1278) Battery
Note the Apple part number is 661-5557.
Apple Original OEM Battery — 50+ available at 119.95 each.
0
Score
Anant
Answered
0
Score
Answered
@ Ruud van der Salm did you get a way to find it ? Mine is a Macbook Pro 2009 (Core 2 Duo) model. I ran the 'System Profiler' application, but could find only the following information. The battery model wasn't listed there.
Battery Information:
Model Information:
Serial Number:
9
Manufacturer: DP
Device name: bq20z451
Pack Lot Code: 0000
PCB Lot Code: 0000
Firmware Version: 0003
Hardware Revision: 0002
Cell Revision: 0100
Charge Information:
Charge remaining (mAh): 472
Fully charged: Yes
Charging: No
Full charge capacity (mAh): 472
Health Information:
Cycle count: 1343
Condition: Replace Now
Battery Installed: Yes
Amperage (mA): 198
Voltage (mV): 12495
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 180
Disk Sleep Timer (Minutes): 0
Display Sleep Timer (Minutes): 180
Wake On AC Change: No
Wake On Clamshell Open: Yes
Wake On LAN: Yes
Current Power Source: Yes
Display Sleep Uses Dim: Yes
Battery Power:
System Sleep Timer (Minutes): 60
Display Sleep Timer (Minutes): 60
Reduce Brightness: Yes
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Wattage (W): 60
Revision: 0x0000
Family: 0x0085
Serial Number: 0x000c47a5
Charging: No
