Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
My iPhone can not format. Whenever I format its showing error message
I can not be restored my iPhone4. Whenever i restored its showing that message. The iPhone could not be restored an unknown error occurred (1). Please advice me what should I do ?
thanks
Score -1
Add a comment
1 Answer
Chosen Solution
Taj, try to put your phone in DFU-mode and then restore. Connect USB, hold home and power button together, after about 7 seconds the phone will turn off. Keep holding home and power for another 3 seconds, now release the power button while holding the home button for another 10 seconds. The phone should be off with a completely dark screen, iTunes should give a message that your phone is in recovery-mode and should be restored. If that does not work, you also want to try a different USB port, a different computer as well as a different cable. Use a USB port on the back of your computer not through a hub or front panel. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Taj will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 1,898
