0
Score
Avatar
Kris
Asked
iPhone 4 screen is very sensitive to presure after a replacement
History
I can't get an answer to this question from anywhere. But after I replace a screen and put it all back together I boot the device and everything is good. Only if i put a little presure on the screen it has this color warp effect for a few seconds. As if the LCD is being squeezed. A factory iPhone does not do this. Is it cheap parts or is there a better reason? How can I avoid this?
Post Answer
0
Score
Avatar
Marcus
103
Answered
PermalinkHistory
A stupid question maybe, but did you remove the protective film on the back of the new display?
The most common cause of this issue is that the replacement glass is of poorer quality and a bit softer than the original, so it flexes when pressurized. This causes the back of the LED-display to get squeezed between the glass and the metal plate housing.
That's what I was suspecting. I tried to be cheap and get the screens off eBay but for the most part they are garbage. Ill keep ordering from my good supplier. And I did remove the film!
Kris,
0
Score
Avatar
Nick
Answered
PermalinkHistory
Who is your good supplier? I have the same problem.
Nick,
Add Your Answer
