Model A1320 / 8 or 16 GB capacity
156 Questions View all
Ok Button is Brocken
I bought a used I Pod 5g. But now i´ve a problem the onliest thing, that wont work is the center button. The rest of the buttons are wotking without problems.
I would be very thankfull, if someone could help me.
Thank you
Score -1
Add a comment
1 Answer
Tornister1994, the first thing I would check, is the switch underneath the center button. Every one of the switches should have a rubber contact on them. This will engage the switch when you push the button. Take a look at my answer on here. It will explain a bit more on how to check the switch. Hope this helps, good luck.
Add a comment
Add your answer
Tornister1994 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 436
