Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
3 days after successful screen repair, stuck on apple logo
I have recently replaced the LCD and digitizer in the iPhone 4 gsm model. The phone worked for 3 days (got the part from icracked) and after 30 min after it was dropped, screen went orange and got stuck on the apple logo. Also the screen is flickering. Any help?
Add a comment
Most Helpful Answer
hard to pin point the actual issue.
try putting in recovery mode and restoring. but if the screen is damamged you would need a new screen assembly
i would try is a new screen assembly if that doesnt work. i would go with www.pacifictoy.com thats who i use. they ship fast too from CA.
do some cleaning on the inside so there is no bridged components.
try them all and just tinker with it a bit.
let me know if it works
Score 1
1 Comment:
Do u think it could be a losse ribbon?
by
Add a comment
HOW TO FIX IPHONE STUCK ON APPLE LOGO
STEP 1: TURN OFF THE IPHONE
To turn off your iPhone you need to turn it on. So turn your iPhone on back to the dreaded screen as normal. When the phone is on hold the sleep/ off button while also holding the home button
If you don’t know where these buttons are; the sleep/ off is on top of your phone. The home button is the only button that is on the same side as the screen. Do this until the phone turns off.
STEP 2: TURN THE PHONE ON
When you turn the phone back on hold the sleep/ off button while holding the volume up button.
STEP 3: GET THE PHONE WORKING
While holding the sleep/ off button and the volume up button, wait for it to turn on. As soon as the phone comes on with the logo, let go of the sleep/ off button. Do not let go of the volume up button.
Hold it until the phone gets back up and running. This can take several minutes but do not give up on it. You can very much assume that you have almost solved your iphone stuck on apple’s logo issue on your own.
STEP 4: LEAVE IT ALONE
Once the phone is back up and running do not bother it. Leave your phone alone for about 30 minutes. Your phone is rather glitchy now and toying with it will make it worse. You can even put it back in the state that it was in.
That’s pretty much it. Your phone is fixed. If you are still experiencing this problem then you might want to send the phone back to Apple and let them run a diagnostic to fix it. This is how one of my friend fixed iPhone Stuck on Apple Logo issue on his own and I hope this little tutorial proves to be helpful for you too . If it didn't work, I suggest you to use FonePaw iPhone Data Recovery. This tool can solve this issue, too.
Score 1
Add a comment
Don't worry, just follow these steps to fix iPhone stuck at Apple logo
=> First of all Start your Computer and then connect with internet connection, now Download the latest version of the iTunes application
=> Now install the iTunes application in your System and connect your Device with computer via Data cable
=> Now connect your Device with iTunes application and then Tab on summary option, see in the left side bar of iTunes
=> Now Select restore option from iTunes and then confirm the Restore Message for better results, After this unplug your Device and Restart it
I hope that will surely
Thank you...
Read more: http://www.recovery-ipad.com
Add a comment
Here is a fix for the "iPad/iPhone stuck on Apple Logo"
1. Hold down the power (top) and home (bottom) buttons at the same time for about 10 seconds.
2. Do the same thing while the phone is being powered
3. Do a restore through iTunes. If your computer is not picking up the phone, try doing step 1 while it is plugged into the computer with iTunes open
Add a comment
When your iPhone gets stuck at the Apple logo and does not boot up completely, it triggers a mini heart-attack. But it’s not all that serious. You can fix this through a couple of ways.
While the first method shows you how iTunes can help you, for the second method, you’ll need a tool like TinyUmbrella.
Let’s take a look at how you can fix an iPhone stuck at the Apple logo during boot:
Step 1: Connect the iPhone to your computer via the USB cable.
Step 2: Put your iPhone in DFU mode
Step 3: Now, all you’ve got to do is ‘Restore’ your iPhone
Now, that’s the simplest way to get your iPhone out of the Apple logo. But what if you have data that hasn’t been backed up? Or if you’re getting errors when you try to restore?
We’ve covered some material on iTunes errors: the most notable errors that you’d be getting are 1014, 1015 or the 16xx series of errors. You can fix these by taking a look at our coverage on iTunes errors.
If your iPhone is stuck on the Apple logo and you’ve got data that needs to be backed up, I’m afraid you’ll mostly lose the data unless you can kick the iPhone out of the Apple logo by other means. By this, we mean you can use tools like Tenorshare ReiBoot to fix the recovery mode problem.
More back-up methods you can see here like on how to:
recover whatsapp messages from itunes backup
retrieve deleted whatsapp messages from iphone
Add a comment
In previous i was always use my iTunes backup to extract iPhone data but once my iTunes backup gets corrupt and then i try iPhone 4s data recovery tool. this tool is such a great because now i can recover data directly from my iPhone.
Score -1
Add a comment
Add your answer
toddsifix will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 8
All Time: 2,532
