Xbox 360 S PSU Disassembly
  1. Xbox 360 S PSU Disassembly, Remove Rubber Boots/Screws: step 1, image 1 of 3 Xbox 360 S PSU Disassembly, Remove Rubber Boots/Screws: step 1, image 2 of 3 Xbox 360 S PSU Disassembly, Remove Rubber Boots/Screws: step 1, image 3 of 3
    • Remove rubber boots
    • Remove T10 Screws
  2. Xbox 360 S PSU Disassembly, Cooling Fan Cable: step 2, image 1 of 2 Xbox 360 S PSU Disassembly, Cooling Fan Cable: step 2, image 2 of 2
    • Remove the top shell, flip it over, and place next to lower shell
    • The two halves are connected together via the cooling fan wire. BE GENTLE when separating them
    • In typical Microsoft fashion, they've made it complicated to remove the fan wire. Not only is it wedged between two transistors it's also adhered with an epoxy like substance.
    • Using a craft knife, carefully cut through the epoxy to get the cable free. Work slowly and carefully. The thick substance and awkward angles make this a slightly tedious process
    • Be VERY CAREFUL. You can easily cut the cable here accidentally. If you cut your red/black wires you'll have to patch them. "Slow is smooth, smooth is fast"
  3. Xbox 360 S PSU Disassembly, Cooling Fan Assembly: step 3, image 1 of 3 Xbox 360 S PSU Disassembly, Cooling Fan Assembly: step 3, image 2 of 3 Xbox 360 S PSU Disassembly, Cooling Fan Assembly: step 3, image 3 of 3
    • Remove PH2 screws
    • Remove PH1 screws
    • Removal unnecessary
    • Disconnect cooling fan plug
    • Pull wire through
  4. Xbox 360 S PSU Disassembly, Fan Disassembly: step 4, image 1 of 3 Xbox 360 S PSU Disassembly, Fan Disassembly: step 4, image 2 of 3 Xbox 360 S PSU Disassembly, Fan Disassembly: step 4, image 3 of 3
    • Remove tape in order to remove fan from its housing unit. This also uncovers a hidden screw.
    • Remove 4 PH0 screws
    • Tape will need to be replaced during reassembly. Electrical or kaptom tape will suffice
    • Take note of the amount of filth collected on this fan. Inadequate cooling could kill your supply, or worse, become a fire hazard
    • Remove fan upper housing plate
    • Gently lift the fan up and over the post
  5. Xbox 360 S PSU Disassembly, Fan Model Info: step 5, image 1 of 1
    • Fan model info in case you need to search out new parts
  6. Xbox 360 S PSU Disassembly, Repair Fan Cable If Necessary: step 6, image 1 of 2 Xbox 360 S PSU Disassembly, Repair Fan Cable If Necessary: step 6, image 2 of 2
    • The fans +/- wires are covered by a thin protective sleeve.
    • Apply some electrical or kaptom tape to patch it if necessary.
    • Initially I tried to use shrink tubing here but the smallest diameter I could get around the plug was a 3/8" tube which will not properly seal around the cable when heated
    • If you accidentally cut through the entire cable (+/- wires) you'll have to resolder them together and cover with shrink tubing.
  7. Xbox 360 S PSU Disassembly, Underside Of PCB: step 7, image 1 of 1
    • Remove PCB from lower shell and place face down
    • The metal shield must be removed in order to expose the bottom of the power supply PCB
    • To quickly and safely remove I suggest using ChipQuik on the 2 single sided through holes. Alternatively you can use solder wick
17 other people completed this guide.
Navy Vet 2015
7,296 Reputation
15 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 51
Past 30 Days: 285
All Time: 9,208
