You have the right to repair the things you own—but how easily can that be done?
To find out, our engineers tear down the latest wireless headphones and score their repairability from zero (unrepairable) to ten (easiest to repair) so you can pick a product that is easy to repair and lasts as long as possible.
What makes a repairable device?
It should be straightforward to disassemble and replace whatever’s broken, using parts and instructions supplied (or endorsed) by the manufacturer. But that’s just to start—repairability means so much more. For full details, see our repairability scoring explainer.
Repairability is a moving target
We update our scoring rubric frequently to stay current with new technologies, materials, and design trends. This means that devices scored in years past might not fare exactly the same if they were re-scored today, but they can be readily compared with their contemporaries. For a precise list of criteria used to calculate each score, click the scorecard version number linked to each device below. For a downloadable (CSV) list of all scores, click here.
Wireless Headphones Scores
Sorted by newest to oldest
Apple AirPods Max 2
2026
PROS
  • Magnetic ear cushions are best-in-class for serviceability.
  • The mesh headband canopy is quickly removable, only needing a SIM eject tool.
CONS
  • Internal access is tricky, with extensive adhesive, proprietary fasteners, and limited room to work.
  • The battery, although modular, is deeply buried.
  • Apart from ear cushions, Apple provides no repair parts or instructions.
Fairphone Fairbuds XL (2025)
2025
PROS
  • Tool-free battery replacement and a fully modular headband design—including a separately replaceable cushion, structure, and crossover cable—sets a new standard.
  • USB-C crossover connections simplify disassembly of the entire headphone into individual modules.
  • Fairphone supports repair with thorough repair documentation and spare part selection.
CONS
  • Replacing the charge port may compromise water resistance.
Sony WH-1000XM6
2025
PROS
  • Fully modular internal design—the charge port, battery, drivers, and headband are all individually replaceable.
  • Despite having top-notch ANC, no adhesives hinder common repairs.
  • The battery is housed in a protective shell and secured with screws rather than adhesive.
CONS
  • A finicky mic connector under a rubber seal complicates driver housing reassembly.
  • Sony does not provide repair manuals or spare parts.
Marshall Monitor III
2024
PROS
  • Twist-off ear cushions, a screwed-on headband cushion, and clearly marked battery compartments all make for straightforward repairs.
  • Both batteries use standard connectors and are easily removable, secured only with mild adhesive.
  • Marshall offers repair guidance for some components.
CONS
  • The USB-C port is soldered to the main board.
  • Although the drivers use simple connectors, connected ANC mic wires are soldered in place.
Beats Solo 4
2024
PROS
  • The headband cushion can be replaced with some effort using basic tools.
CONS
  • Ear cushions are glued on and a hassle to replace.
  • The battery is firmly glued in place.
  • Hot glue and soldered connections hamper charge port and driver repairs.
  • Apple does not support Beats headphones with repair manuals or spare parts.
JBL Tune 520BT
2024
PROS
  • The battery uses a standard connector and is easily removable, secured only with mild adhesive.
  • Ear cushions and driver housings are straightforward to access with basic tools.
CONS
  • The USB-C port is soldered to the main board alongside all buttons, rendering replacement impractical.
  • The headband cushion is integrated and inaccessible due to a soldered crossover cable.
  • JBL does not provide repair manuals or spare parts.
JBL Tune 770NC
2023
PROS
  • The driver uses spring contacts and can be separated from its housing, a notable design for this price range.
  • The battery is accessible and uses a standard connector.
  • Snap-in ear cushions are simple to replace.
CONS
  • The headband cushion is glued and integrated, with a soldered crossover cable.
Anker Soundcore Q20i
2023
PROS
  • Snap-in ear cushions are simple to replace with a basic pry tool.
CONS
  • The battery is soldered to the main board, making replacements much more difficult than necessary.
  • Hot glue over solder joints adds extra steps and heating to driver-related repairs.
  • The USB-C port and headband cushion are both effectively inaccessible.
  • Apart from ear cushions, Anker provides no repair parts or instructions.
Beats Studio Pro
2023
PROS
  • The battery can be replaced with some effort using basic tools.
CONS
  • Ear cushions are glued in with strong adhesive, making the most common headphone repair destructive and tedious.
  • A complex path of clips and glue stands in the way of most repairs; reassembly is difficult.
Fairphone Fairbuds XL (2023)
2023
PROS
CONS
Skullcandy Crusher ANC 2
2023
PROS
  • Showercap-style ear cushions are replaceable without tools (if a little tricky to install).
CONS
  • Battery leads are soldered, and the charge port is integrated into the main board.
  • Hot glue and soldered connections hamper repairs to the headband and drivers.
  • Skullcandy does not provide repair manuals or spare parts.
Sony WH-CH720N
2023
PROS
  • The battery uses a standard connector and secures only with mild adhesive, making replacements straightforward.
  • Snap-on ear cushions are easier to reinstall than on comparable models thanks to a stiffer edge.
CONS
  • Driver and ANC mic wires are soldered to the board in each earcup, hampering repairs.
  • The headband cushion is integrated, and removing the headband requires extensive desoldering.
Sennheiser Momentum 4
2022
PROS
  • Snap-in ear cushions can be replaced without tools.
  • The headband cushion and charge port can be replaced using basic tools.
CONS
  • The battery is firmly glued in place, and the driver connections are soldered to the main board.
  • Apart from ear cushions, Sennheiser provides no repair parts or instructions.
Bang & Olufsen Beoplay HX
2021
PROS
  • Bayonet-mount ear cushions and a clip-in headband cushion make the two most wear-prone parts easy to replace, with how-to videos available from B&O.
  • The battery is easily removable with a standard connector and mild adhesive.
CONS
  • Drivers are sealed into their housings and must be replaced as a unit.
Apple Airpods Max
2020
PROS
CONS
