Pro Tech Toolkit
$59.95
Add to Cart
Persistent
Innovation
Armed with the data from hundreds of teardowns and thousands of repair guides, our engineers built the most effective toolkit for your practical repair needs.
Lifetime Warranty
We believe in our tools, and we’ll stand behind them. That’s why our Pro Tech Toolkit comes backed by iFixit’s Lifetime Warranty. If something breaks, we’ll replace it—for as long as you own the toolkit.
See What's Inside
Quality To
The Core
At the heart of the toolkit, 64 steel screwdriver bits to service all your tech. The Pro Tech Toolkit has everything from a Y000 bit for next-gen Apple products to the Gamebit for vintage game consoles.
64 Bit Kit
4 mm Bits Include
Phillips
000, 00, 0, 1, 2
Flathead
1, 1.5, 2, 2.5, 3, 4 mm
Torx
T2, T3, T4, T5
Torx Security
TR6, TR7, TR8, TR9, TR10, TR15, TR20, TR25
Pentalobe
P2, P5, P6
JIS
J000, J00, J0, J1
Hex
0.7, 0.9, 1.3, 1.5, 2, 2.5, 3, 3.5, 4, 4.5, 5 mm
Tri-point
Y000, Y00, Y0, Y1
Nut Driver
2.5, 3, 3.5, 4, 4.5, 5, 5.5 mm
Square
0, 1, 2
Gamebit
3.8, 4.5 mm
Spanner
4, 6, 8
Triangle
2, 3 mm
SIM Eject Bit
1/4" to 4 mm Driver Adapter
Deliberate
Tool Selection
We’ve engineered this toolkit from the ground up—from the custom opening tools and spudgers to the iFixit-designed aluminum driver with knurled handle and swivel top.
Opening Pick
Opening Pick
Ultra-thin pick for slicing adhesive and separating screens and cases
Anti-Static Wrist Strap
Protects your electronics from electrostatic discharge (ESD) damage during repairs
Metal Spudger
Metal Spudger
Dual-tipped metal spudger for more powerful prying, scraping, and probing
Spudger
Spudger
Anti-static tool with pointed and flat ends for safely prying cables and sensitive electronics
64 Bit Driver
64 Bit Driver
Ergonomic handle provides plenty of torque with swivel cap and magnetized bit holder
Jimmy
Jimmy
Flexible steel blade with an ergonomic handle for precise and powerful prying
Flex Extension
Flex Extension
Extend your reach and get more torque to screws in hard-to-reach places
Reverse Tweezers
Reverse Tweezers
Spring-action tweezers hold cables or components hands-free
Angled Tweezers
Angled Tweezers
ESD-safe tweezers with angled, pointed tips for hard-to-reach places
Blunt Tweezers
Blunt Tweezers
ESD-safe tweezers with flat, rounded, blunt tips for delicate and precise manipulation
Opening Tool
Opening Tool
Gets into the tightest cracks without scratching or marking your workpiece
Suction Cup
Suction Cup
Light-duty suction cup for removing phone and tablet glass panels
Specifications
Tool Roll Dimensions (Folded)
8.4″ × 7.6″ × 2.8″
Tool Roll Dimensions (Flat)
22″ × 7.6″
Tool Roll Material
Polyester Canvas
Weight
1.5 lbs
4 mm Bit Material
6150 Steel
Bit Driver Material
Anodized Aluminum
Bit Case Material
Recycled ABS
Bit Case Foam Material
EVA
Developed
In California
We obsess over quality. Here’s a look at how we develop the best tools for repair.
Broken Isn’t The End
Screens crack. Laptops slow. Batteries fail. Wear and tear is normal, but throwing away fixable stuff shouldn't be. Repair is better for your wallet and the environment. You don’t need to be a Genius to fix your electronics. You just need the right tools.
