iPhone 4 LCD Screen and Digitizer (GSM/AT&T)
$34.95
$34.95
We'll send a message when the product is back in stock.
Product Details
Features
Features
This part will only work in a GSM/AT&T iPhone 4. It will not work in an iPhone 4s or in a CDMA/Verizon iPhone 4. Identify your iPhone correctly in one step.
  • Brand-new replacement screen for any GSM (e.g. AT&T/T-Mobile) iPhone 4. Each screen is hand inspected and cleaned by an iFixit tech.
  • This part includes the front camera bezel and speaker mesh.
  • This part does not include the iPhone 4 Home Button Assembly.
  • Already have the tools on hand? Select the "Part Only" option.
  • Missing a tool or two? Select the "Fix Kit" option and get everything you need.
  • Consider getting a nifty screen protector, so your new iPhone display assembly can play nice with your keys.
Kit contents:
  • New iPhone 4 LCD Screen and Digitizer
  • Pentalobe 5-point screwdriver
  • Phillips #000 screwdriver
  • Small flathead screwdriver
  • Plastic spudger
  • Plastic opening tool
  • Sim card eject tool
  • Alcohol Prep Pad
Compatibility
iPhone 4
16 GB
32 GB
8 GB
Repair Stories
User avatar
luisosw's Story Photo #663662
luisosw's Story Photo #663658
luisosw's Story Photo #663664
My Problem
My father is an avid runner and he likes listening music while he does it. Once he was running and his phone just fell off and hit the ground. The display got cracked in one corner, next to the home button. It was operational, but nothing like a scratchless white iPhone , isnt it? :)
My Fix
Never had done a . . .
User avatar
epdi's Story Photo #676472
My Problem
A friend dropped her iPhone and cracked the screen. It happened to be one of those days. She was feeling pretty down on life. I "borrowed" her phone and ordered the repair kit.
My Fix
Awesome step-by-step instructions! The repair went without a hitch. I opened the kit and an hour later had an almost new iPh . . .
User avatar
Daniel Hunt's Story Photo #905155
My Problem
My wife dropped her iPhone 4 one too many times and it stopped displaying at all. The phone still worked as we could her sounds when swiping it open or taking screen shots, but no display. Maybe the display connectors just came loose, but if I was going to open the phone to check, it was worth all . . .
User avatar
My Problem
An older iPhone 4 with a cracked screen was going to waist in my dresser. I found myself reading for it when my new fone was on the charger but e screen was a mess.
My Fix
The repair wint great. No issues not if is a pleasure to use for late nite browsing and email. I forgot hi good the smal screen actu . . .
User avatar
My Problem
The screen and digitizer was cracked.
My Fix
The repair went great with the help of this website and some patience. When I first plugged it in the screen didn't work right away but I kept it on charge for a while and after about 30 min it worked perfectly.
My Advice
The LCD screen was cracked and was leaking oil all o . . .
User avatar
User avatar
My Problem
I was given a "hand-me-down" iPhone with a cracked screen.
My Fix
With the right parts and the step-by-step instructions ... great!
My Advice
1. Read through the instructions to get a sense of what can go wrong.
2. LABEL or identify those screws, they are not interchangeable.
3. Loosen the 6 washers and screws on th . . .
User avatar
User avatar
My Problem
The screen and rear case cracked. The battery's power went fast.
My Fix
Follow instructions of the repair guide on the webpage "iPhone 4 Display Assembly Replacement", assemble step by step and reassemble step by step in reverse order.
My Advice
1. Be careful with messages in red color in the guide
2. Screws label wit . . .
User avatar
My Problem
I couldn't use it the glass was completely smashed
My Fix
I broke something the first time I tried to replace the parts so I had to buy and try it all over again. The second time I did it in under an hour and it works perfectly. Practice makes perfect. The success gave me total confidence and now at 14 y . . .
Show more
