Battery
2 Answers 2 Score |
My touchscreen is tapping the corner of the screen |
1 Answer 0 Score |
Why is my laptop screen not on but it makes the on sound |
1 Answer 0 Score |
Doesn't charge or turn on. |
1 Answer 1 Score |
How do I replace the keyboard? |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
Released in June 2010, the Dell Inspiron Duo was introduced as an appealing notebook-tablet hybrid. It has a hinged display that can flip 180 degrees vertically allowing for both tablet and traditional laptop configurations. While the screen is flipped and in tablet configuration, it has a touch-screen friendly tablet interface, and while in laptop configuration it uses the standard Windows 7 interface.
Identification
You can identify this device by using the Service Tag number, or Serial Number. It's a seven digit alpha-numeric code on the bottom of the device, you can enter it here under "Enter Service Tag or Express Service Code", about halfway down the page. While this device was released in many different color combinations, you can identify the device by looking for common features. There should be a shiny silver power button on the back bottom right corner of the device, and on the opposite side of the device in the same position should be the power cable port. There are two speakers, located on the front bottom right of the device. There is a docking point for the Audio Station located on back of the device, in addition to the four heal release vents. On the touch screen, it will read "INSPIRON duo" on the top left, and the Dell Logo will be bottom center.
Specifications
- Processor: 1.5GHz Intel Atom N550
- Memory: 2GB, 1333MHz DDR3
- Hard Drive: 320 GB 7,200 rpm
- Chipset: Intel NM10
- Graphics: Intel GMA 3150 Integrated Graphics
- Wireless Networking: Atheros WB195
- Original Operating System: Windows 7 Home Premium
- Battery: 4-cell 29 Watt Hour Lithium Ion
- Dimensions: 11.2 x 7.7 inches
- Height: 1.0 - 1.1 inches
- Screen Size: 10.1 inches
- Weight: 3.0 pounds
