Polaroid OneStep closeup Troubleshooting
Created in 1983, the Polaroid OneStep closeup has flash and can develop a picture right in front of your eyes.
Flash isn't working
  • Change batteries
  • Change flash bulb
Blurry Pictures
  • Problems with impossible project film
  • make sure the lens is clean and unobstructed
Picture taking switch stuck
  • Replace the switch
Pictures not coming out at all
  • Change film
  • Broken rollers
Camera not turning on
  • Change battery
Flash isn't working
If the flash isn't working, it may be as simple as a couple dead batteries, changing the batteries for the flash is shown in the guide. Also, the clash bulb may be broken. Changing the flashbulb is also demonstrated in the guide.
Blurry Pictures
After taking a picture with your device, if the pictures come out blurry, there may be problems with the impossible project film. The camera itself may not be to blame. Secondly, make sure that the lens is clean and unobstructed.
If the switch for taking pictures is stuck, you may need to replace it. This will be demonstrated in the tear down guide.
After taking a picture, if the pictures are not coming out at all, changing the film may be a simple fix. If there is film, the rollers which feed out the film may be broken. Replacing the rollers will also be demonstrated in the tear down guide.
If your camera is not turning on, the battery may need to be changed, which will be demonstrated in the tear down guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 167
