Causes
When using the SodaStream Source to make soda, using warm water generally results in fewer bubbles. Cold water is recommended for best results and more bubbles. Clean out the carbonation bottle and refill it with cold, unflavored water, and try to use the machine again.
For fizzier soda, SodaStream recommends using unflavored carbonated water. The soda will have more overall fizz because you are adding more carbonation, to begin with. You should not be using juice, flat soda, or any other previously flavored liquids. Clean out the carbonation bottle and refill it with clean, unflavored, carbonated water, then try to use the machine again.
Haven't found the solution to your problem?Browse our forum
