Student-Contributed Wiki
An awesome student from our education program made this wiki. It is not managed by iFixit staff.
Protocol Slipstream EVO Troubleshooting
Weak Controller Response ¶
Controller batteries are low ¶
Checking the charge of the controller. Replace batteries in the controller with AAA batteries.
Low Drone battery ¶
Check Drone Batteries ¶
If you are still experiencing problems with keeping the drone in the air, check the charge for the drone. If lights do not turn on, plug the battery with the charger provided in the box.
Connection Problems ¶
Check your surroundings ¶
If you are flying outdoors make sure you are flying within an open area free of objects that can get in the way of the connection between the controller and drone such as trees and buildings. If you are having troubles getting the drone off the ground check if synchronization was done.
Flying Problems ¶
Re-synchronize ¶
If you are having troubles getting the drone to hover or are having troubles maneuvering the drone, the synchronization was not done when the drone was on ground level. Re-do the synchronization with the drone on ground level.
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 19
All Time: 307
