Causes
If the Lenovo IdeaPad U530 Touch laptop’s battery was drained during its last use and it is not turning on while it is plugged in, there may be a problem with the AC adapter or charging cord. Inspect the adapter for the computer and make sure that the cord is not damaged. If the cord is damaged, seek a replacement adapter.
If the cord is not damaged, reinsert it into the laptop’s charging port and remove all other physical connections to the computer (such as USB drives). Check that the AC adapter is directly connected to a wall socket and is not running through any surge protectors or extension cords. Try using another device from the same power source to be sure that the wall socket is providing power.
If your Lenovo IdeaPad U530 Touch laptop is not turning on or showing any signs of life, it may have a malfunctioning battery. Disconnect the computer from its charger and use this battery replacement guide to remove the laptop’s battery. Then, reinstall the battery and try to turn it on as usual. If that does not work, connect the laptop’s charger and try to turn on the computer.
- 10 minutesEasy
Questions other people have asked about this
- Why doesn't the laptop turn on?
- My laptop suddenly stopped working and now it's not starting.
- Why does my laptop keep turning off and on?
- Why won't my laptop turn on after a sudden shutdown?
- My device won't power on
- Why won’t it start up?
- My laptop is not starting
- The laptop won't turn on
- Why is my laptop not turning on?
