Causes
Some users have reported a bolt falling out from the bottom of the machine. The bolt holds the washing machine’s main pulley on. Over time, the bolt can back itself out of the pulley’s assembly, causing the pulley to fall down and rub against its plastic cage. This can cause a ratcheting sound and a burning smell. Check underneath your washing machine for any loose bolts. Also, check to see if the machine’s drive pulley has fallen down and is rubbing against its plastic cage. If so, use a new bolt and spring washer to reattach the pulley belt.
If your washer continues to make a loud noise during the spin cycle, the machine’s clutch assembly might be worn out. The clutch assembly makes the connection between the washing machine’s transmission and the inner tub. The clutch assembly allows the tub to gradually get up to the proper spin speed. As the clutch wears out with age, it may become noisy during the spin cycle or just after the spin cycle finishes. If the clutch is loud or not working properly, it will need to be replaced. Use the Kenmore 110 Series Washing Machine Transmission Clutch Replacement Guide to replace the machine’s clutch assembly.
- 1 hourDifficult
The washing machine’s rear drum includes bearings in it to keep the inner tub spinning smoothly. If the tub bearing system is defective, the washer may become very noisy, especially on the spin cycles. On some washing machines, the bearings are sold separately from the rear drum. However, experts recommend replacing both the outer drum and the bearings as an assembly, if the manufacturer sells the components together. Removing and pressing in the new bearing can prove difficult, but replacing the outer tub and bearing together is slightly easier.
Questions other people have asked about this
- "Ratcheting" noise in wash cycle only
- Washer makes very loud noise during spin cycle
- Loud banging noise only during spin cycle
- Why is my washer leaking and making noise?
- Loud banging during spin/out of balance
- Loud Noise During Spin Cycle
- Loud knocking noise and when the cycle completes
- Kenmore type 110 washing machine buzzing noise
- Grinding Noise when turning even by hand.
- Why is the washer making noise and jumping during the spin cycle?
- There is a terrible thumping noise and vibration when in use.
- It is making loud clicks and even a couple of bangs
- My washer is making a bad noise
- Why is my Kenmore washer making loud noise during spin cycle?
- Why is my Kenmore Washer creating a load noise during the Spin cycle.
- Kenmore Washer Spin cycle noise
- Loud chunk-a chunk-a sound during agitate cycle
- Kenmore 110 washer howls during spin cycle
- Noisy operation duirng wash cycle
- Why is my washer making a loud noise when it starts?
