Student-Contributed Wiki
An awesome student from our education program made this wiki. It is not managed by iFixit staff.
Insignia Flex NS-P11W7100 Troubleshooting
The Insignia Flex is a 11.6" tablet, identified by model number NS-P11W7100; this page is meant to guide you to any necessary repairs.
Insignia Flex Will Not Power On ¶
This Device will not turn on, or turns off as soon as it starts.
Device Will Not Charge ¶
If your power adapter is faulty, your tablet will be able to run off battery power until the battery itself is dead. One way to test for this possibility is to try using another charger. If your tablet is not then able to charge it is time to replace your charging adapter. It can be replaced by following [this link].
Faulty Battery ¶
If your Windows Insignia Flew will only power on when plugged in via your device charger, then the battery is faulty. It can be replaced by following [this link].
Power Button Does Not Work ¶
If you know your charger is functioning properly and battery failure has been ruled out, the external power button may be inoperable. To replace the power button follow [this link].
Audio Is Not Functional Or Is Distorted ¶
Device does not produce any sound or the sound quality is consistently low.
Speakers Do Not Produce Sound ¶
If the device does not produce external sound and is still able to produce sound through the use of headphones, then the speakers need replacing. You can replace your external speakers by following [this link].
Headphones Do not Produce Sound ¶
If an external sound device is plugged into your tablet but is unable to produce any sound, your headphone jack (also known as an auxiliary port) may be faulty. You can replace your auxiliary port by following [this link].
Camera Is Unresponsive ¶
Camera application shuts down or does not operate properly.
Camera Is Cracked ¶
If your camera has a cracked lens, you can replace the camera by following [this link].
Camera Is Damaged ¶
If your camera has visual signs of damage and does not operate properly, you can replace the camera by following [this link].
Screen Does Not Turn On ¶
The screen has cracks that interfere with use or will not turn on at all.
Screen Is Cracked ¶
If the screen is cracked, it may be in need of replacement. You can replace your screen by following [this link].
Screen Is Unresponsive ¶
If the screen is completely unresponsive, it may be faulty. Check to ensure that the touch screen settings are enabled. If this does not solve the issue, you can replace your screen by following [this link].
0 Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 71
All Time: 1,227
