Table of Contents
Screen is cracked
*Screen replacement guide
For Screen replacement tips, please refer to our Digitizer replacement guide. The link will be below.
Coby Kyros MID9742 Digitizer Replacement
Device will not charge
*Bad cable connection
Check the USB cable for damage and dirt, especially at the ends. Then try using the wall charger, as this will provide greater power input than the computer/USB.
*Broken charger USB
Try using different chargers to see if you may have a problem with your charger or cord.
Device will not turn on
*Drained Battery
Plug your device into your computer or wall adapter to charge. If it does not charge when connected to either of these, you probably have a dead battery. The battery will need to be replaced with a new one.
*Bad display
It is possible that it appears nothing is happening because the display is bad. If the tablet sounds like it is working properly but nothing is visible, it is possible the display is bad and must be replaced. Unfortunately, the LCD and glass panel are fused together, and must be replaced as one unit.
*Bad logic board
If nothing else works, your logic board is probably bad and needs to be replaced.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 84
