Blender will not turn on
No matter what you do, you can't get your blender to turn on.
The blender is not plugged in.
Check to make sure the power cord is connected to a power outlet.
Power cord has faulty connections.
Repairing Black and Decker BL3000S Power Cord
Circuit board has faulty connections.
Black and Decker BL3000S Circuit Board
Blender leaks
The contents of the glass jar come out.
The lid is not properly attached to the jar.
Unplug the device. Make sure the top lid fits snugly on the top of the jar. This should prevent contents of the jar from coming out the top.
The blades at the bottom of the jar are not properly screwed in.
Unplug the device and remove the contents of the jar. Unscrew the bottom portion of the jar containing the blades. Make sure nothing is blocking interfering with the threads. Re-screw the bottom portion on, making sure the seal is tight. This will prevent contents from leaking out.
There are cracks in the jar or lid.
Inspect the jar body and lid for cracks or holes. If one of these problems is found, a replacement part must be ordered.
Blades will not turn
The device is on, but the blades do not begin to rotate.
Jar is not properly seated on the base.
Unplug the power cord and remove the jar from the base. Check to make sure that there is not any food or other obstructions on the connecting gear. Place the jar back so that the connecting gear on the base matches with the gear on the jar bottom. Make sure bottom connecting piece sits level on the base.
Food is jammed between the blades.
Unplug the power cord and physically remove the obstruction from the blades using a screwdriver if necessary. Once finished, manually turn blades to ensure they will now turn. Use care as to not cut yourself on the blades.
The motor is burnt out.
The motor is not replaceable. A new blender must be purchased.
Blades do not cut/blend efficiently
The blender blades will not cut certain items or take a long time to blend certain items.
Unplug the power cord and physically remove the obstruction from the blades. Use care as to not cut yourself on the blades.
The blender blades are not sharp anymore.
Remove and replace the blender blades using the following guide.
Black and Decker BL3000S Blender Blades Replacement
Blender buttons do not work
The buttons on the blender do not respond.
The connection between the buttons and the circuit board is not complete.
Black and Decker BL3000S button panel replacement
Blender stops suddenly during use
As you are using the blender, the blades stop turning all of a sudden.
Blender becomes unplugged during use.
Blender may have been unplugged during use. Check to make sure it is still connected to a power outlet.
The motor overheats.
The fan may not be functioning anymore.
16 Comments
What should I do I blender suddenly stopped working
Madhulika Srivastava - Reply
Trying to remove the bottom part that will connect blade?
Very hard! IT will not come out so I can clean up the cup?
Elaine TS - Reply
Please, how to remove the white part that is attached to the bottom of food processor jar? I cannot find my manual!
Need to wash the parts!!!
Elaine TS - Reply
My motor runs but the blades do not move. No food is stuck. I loosened the spinning part but it only ran for about 2 seconds before jamming again. Is it worth fixing?
judi969 - Reply
What can I do you win the blender part will not fit on the canister really more to do with anything?
Rita Benton - Reply
