Eufy Robovac 11s Max Not Charging
If your Eufy Robovac 11s Max vacuum is not charging, follow these instructions for solutions.
Causes
Look at the battery charging ports on the vacuum (the metallic squares under the body). If you notice anything blocking the charging port, try to remove it. You can use a dry and clean cloth to do so.
2
Look at the battery symbol on your vacuum. If the battery indicates low power, the vacuum needs to be charged. If the Robovac will not turn back on, give the charging dock some time to recharge the battery.
3
If your battery is old or damaged, you may need to get a replacement. To do this, you can order a new battery on Eufy's website.
Describe your problem in your own words
View statistics:
Past 24 Hours:3
Past 7 Days:14
Past 30 Days:43
All Time:569
