Shop the Holiday Gift Guide
Bumping into Walls
Ashish Shrestha and 2 contributors
Last updated on
If your Shark RV912S EZ robot vacuum is bumping into walls, falling off ledges, getting stuck, or moving erratically, this troubleshooting page may have a solution to the problem.
Causes
Through consistent use or long periods of storage, the sensors may become covered by dust or debris, preventing the device from moving properly.
● Locate the sensors at the front of the device.
● Use a lint-free cloth with isopropyl alcohol to gently clean the sensor.
2
If the wheels of the device are blocked or damaged, they will not move properly. As such, the device will not be able to correctly control where it is moving.
● Flip the device over and inspect the wheels and axles for external debris or damage.
● Use tweezers to remove any debris that can’t be removed by hand.
If no external debris is found or there is obvious damage, the wheels may need to be removed and then cleaned or replaced.
● Refer to this guide Shark RV912 EZ Front Wheel Replacement to see how to remove and replace the device’s front wheel.
3
If the device’s sensors are clean and the wheels are working properly, then the device’s software may be malfunctioning.
● Reset the device by turning it off and then back on. This should fix any temporary bugs.
If this does not solve the issue with the device, it could be in need of a firmware update.
● Ensure the SharkClean app is downloaded and that your profile is set up.
● Check the dashboard or settings on the SharkClean app for an update prompt.
● If a prompt is found, navigate to settings and select the update to begin the firmware download.
As a last resort, the device's floor plan can be deleted and remade on the app.
● Go to settings on the app.
● Pick the correct device and select “Map Data”.
● Select “Delete Map Data.”
● Run the device.
Running the device for the first time after deleting its old floor plan will cause it to explore the room and create a new one. If the device still isn’t moving correctly during this phase, the floor plan is not the issue.
4
If none of these issues apply to the device, then at least one of the sensors is likely broken and needs to be replaced.
Describe your problem in your own words
View statistics:
Past 24 Hours:10
Past 7 Days:14
Past 30 Days:47
All Time:236
