Shop the Holiday Gift Guide
Causes
If the power adapter or outlet isn’t providing electricity, the robot won’t charge.
● Make sure the adapter is securely plugged into both the dock and the wall outlet.
● Test the outlet with another device or try a different outlet.
● If the dock’s LED doesn’t light up, replace the power adapter.
Dust or debris on the charging contacts can block the electrical connection.
● Turn off the robot and unplug the dock.
● Clean the metal contacts on both with a dry cloth or cotton swab.
● Avoid water or chemicals that could cause corrosion or damage the internals.
● Dock the robot again and check for the charging light.
A loose or old battery may not hold or receive a charge.
● Remove the battery cover and check that the connector is secure.
● Look for swelling or corrosion.
● Replace the battery if it no longer holds a charge.
● Refer to this guide Shark RV912 EZ Battery Replacement for information on how to replace the battery.
Related Problems
Shark RV912S EZ
2 problems · View all
Describe your problem in your own words
