Logitech G Cloud Unresponsive Joysticks
If the joysticks on your Logitech G Cloud are unresponsive, this page offers solutions for the issue.
Causes
Residue can build-up over time in the device and cause malfunction. Use a cotton swab with isopropyl alcohol and trace around the joysticks. This will loosen build-up and restore device function.
2
Over time, usage can lead to inaccurate measurements in the device's systems. The device may need to be recalibrated to restore normal function. Calibrating the device will improve joystick accuracy to factory settings.
To recalibrate the Logitech G Cloud, turn the device on and click the Settings icon in the top left corner. From here, press “Controller,” then “Joystick Sensitivity” to return sensitivity to default. Alternatively, press “Joystick Dead Zone Settings” for increased or decreased mobility.
3
Restarting the device restarts each of the systems in the device. Turning it off and back on again can return the device to its original settings and allow it to function correctly. Pressing and holding the button will bring a separate screen up. Press “restart”. This will turn off all background processes and restart all systems, allowing it to operate smoothly.
Updates contain bug fixes that could resolve improper function. Updates are released by the developer of the device and add support to the software. Updating the device updates the software. To update the Logitech G Cloud, turn the device on and click the Settings icon in the top left corner. From here, press “System Updates,” then “Check for Updates.” Update the device if there is an available update.
4
If you've checked everything and your joysticks are still not responding, you may need to replace them. Follow this Logitech G Cloud Right Joystick Replacement guide and/or the Logitech G Cloud Left Joystick Replacement guide.
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:6
Past 30 Days:41
All Time:888
