Lenovo Thinkpad L590 No Audio Output
Tavius Wilson and 2 contributors
Last updated on
Are your Lenovo Thinkpad L590 speakers not producing audio? Use this troubleshooting guide to help diagnose why.
Causes
Ensure that your volume is not muted and check if any connected Bluetooth devices have an independent volume switch from the laptop
2
Check the windows troubleshooter before anything else. Press the windows key and search "find and fix problems with playing sound" run the troubleshooter to find the problem
3
Update your drivers. Press the windows key and search "device manager" navigate to audio inputs and outputs, select your speakers, press driver at the top of the pop-up window and then press update drivers and then press "search automatically for drivers"
4
Double check that the audio settings are set to the right device. In order to go about this, you need to right click on the sound icon on the task bar. After that, choose "Open Sound Settings" and under "Output" select the device you want to play sound on.
View statistics:
Past 24 Hours:
0
Past 7 Days:
0
Past 30 Days:
11
All Time:
171
