Causes
Drivers are essential to make any device work efficiently and properly. If your OS has updated, this could make different drivers incompatible. In order for the drivers to be updated, you can follow the instructions below
If you already have the Lenovo driver updater installed, follow the instructions on how to update your drivers on you Lenovo L490
- Right click the start menu on the taskbar and select "device manager"
- Expand the "Network Adapters" section
- Right click your Wi-Fi adapter and select "Update driver"
- Choose "Search automatically for updated driver software
In order to properly support your network, configuring your Network in Powershell could help out with computer connections
- Open Windows Powershell as the administrator
- type ipconfig /all to check your network settings
- In order to renew your IP address for a new connection type these in the command prompt
- ipconfig /release
- ipconfig /renew
Resetting the Network Adapter is similar to resetting the Network setting. This can properly make sure that your Adapter is running ok
- Go to control panel
- Click Network and Sharing Center
- Click Change adapter settings
- Right click on your network adapter and select "Disable". Wait a few seconds, then right click and select "Enable"
You're seeing solutions for Lenovo ThinkPad L490. Select your model to find parts for your device.
