If there are no lights, fan, or screen activity when pressing the power button and no response, even when plugged into the adapter cable, follow this troubleshooting guide for possible solutions.
Causes
  • Perform a hard reset
    • Disconnect the battery and AC power.
    • Press and hold the power button for 30 seconds.
    • Reconnect the power adapter and try turning it on.
2
  • Check the power adapter
    • Check and confirm that the power adapter delivers 20V DC using a multimeter or another working power adapter.
3
  • Boot on Thinkpad L460 without the battery
    • Remove the battery, plug in the adapter only, and power on.
    • If the Thinkpad L460 starts, the battery most likely needs replacement. Follow this guide to replace the battery.
4
  • Reseat the components
    • Open the bottom cover of the Thinkpad L460.
    • Remove and reinstall the RAM and SSD/HDD.
5
  • Inspect the power button cable
    • Check and ensure the ribbon cable is properly connected to the motherboard.
6
  • Replace the motherboard
    • If all of the above solutions fail, professional replacement may be required.
Describe your problem in your own words
View statistics:
Past 24 Hours:1
Past 7 Days:3
Past 30 Days:28
All Time:338
