Lenovo Flex 3-1580 Touch Screen is Unresponsive
Florence Hall and 2 contributors
Last updated on
If you are touching the screen of the Lenovo Flex 3-1580 and there is no activity or response, follow this page for solutions.
Causes
If the touch screen on your laptop is not working properly you should first try cleaning the screen.
  1. Take a damp piece of cloth and wipe down the screen until clean.
2
Something else that could possibly cause that delay are the drivers needing to be updated, specifically for the touchscreen function.
  1. This can be checked by navigating to the Device Manager application.
  2. In the start menu type "Device Manager" and select it from the results below.
# Click on the black arrow to the left of “Human Interface Devices” to bring down more options.
  1. Then right click on the “HID-compliant touch screen”
  2. You should have an option for you to check for any updates. If there are any, download those and this will help resolve the issue.
If not automatically done once downloading if finished, go ahead and restart the Lenovo Flex 3-1580.
3
  1. In order to update that software go down to the bottom of your screen in the search bar (start menu) and type in “updates”. What should pop up first is “Check Updates” .
  2. You will click on that to see if you have anything that needs to be updated. Even if it says “no updates” there should be another “check updates” in that tab you can click on to double check.
  3. If there is an update needed you will click download.
4
  1. You will go down to the start menu and there you will see a power symbol.
  2. Click on that power symbol and select the shutdown option, your computer will take a few minutes to restart.
5
  1. In order to calibrate your touch screen system you will need to open your setting bar which will be at the bottom left of your computer screen.
  2. Click on system and select “tablet PC settings.”
  3. Click on calibrate and you should see instructions you need to follow.
  4. This will instruct you to touch the designated points with your finger.
6
If there is any noticeable physical damage, it is possible that the screen will need to be replaced. This can be done in a local professional repair shop.
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
14
All Time:
80
