Shop the Holiday Gift Guide
Coffee or Water Does Not Reach Target Temperature
Introduction
Is your Keurig K-Duo water not heating up or reaching the target temperature? Use this troubleshooting guide to help diagnose why.
First check the power, as commonly Keurig’s can be finicky with outlets so first try unplugging then replugging in the power cord to the same or different outlet.
Causes
After all these tests, if the hot plate is still not working try resetting the machine again. Unplug it for 5-10 minutes to reset the machine. Now once plugged in and fully cleaned the machine should start running again.
In order to increase the longevity of the Keurig K-Duo make sure to deep clean the machine on occasions before the these issues arise.
Related Problems
Keurig K-Duo
3 problems · View all
Describe your problem in your own words
