Learn how to fix just about anything with our step-by-step guides.
Share solutions and get help from a friend.
Get a sneak peek inside the latest gadgets.
The friendly AI repair assistant.
Help teach people to make their stuff work again.
Learn about the Right to Repair movement and how to be an advocate.
Learn why fixable products make sense.
Your pocket repair helper.
Quality parts and tools backed by our lifetime guarantee.
Shop our wide selection of precision tools.
Shop parts backed by our quality guarantee.
Batteries tested and guaranteed plus a kit with everything you need.
HP EliteBook 840 G4 Does Not Power On
If you press and hold the power button on your HP EliteBook 840 G4 and the device does not power on, follow this page for possible solutions.
Disconnect AC + main battery, hold Power button 30–60 s, then reconnect AC only. This “hard reset” clears latched power circuits, very common G4 fix.
Disconnect all power sources, inspect board for corrosion; clean with isopropyl alcohol or seek professional board repair.
Remove bottom cover. Disconnect main battery. Try to power on using AC only. If stable, replace the battery.
HP EliteBook 840 G4
3 common problems
