HP EliteBook 830 G6 Camera Not Working
Camera Not Working
If your HP EliteBook 830 G6 camera shows a black screen, does not respond, or displays a “No camera found” error, try these troubleshooting steps. Follow each solution in order to restore camera functionality.
Causes
Problem: The camera lens is physically blocked by the built-in privacy shutter.
Solution:
  • Locate the small slider above the display.
  • Move it to open the camera shutter.
  • Test the camera in the Windows Camera app or video-conferencing software.
Guide Placeholder: [Privacy shutter check guide – coming soon]
2
Problem: Windows privacy settings may prevent apps from accessing your camera.
Solution:
  1. Open Settings → Privacy → Camera.
  2. Turn Camera access for this device ON.
  3. Enable Allow apps to access your camera.
  4. Scroll down and make sure the specific apps (Zoom, Teams, etc.) have camera access.
  5. Restart the app and test the camera.
Guide Placeholder: [Windows camera permissions guide – coming soon]
3
Problem: The camera may be disabled or unrecognized by Windows.
Solution:
  1. Press Windows + X → Device Manager.
  2. Expand Cameras or Imaging Devices.
  3. Right-click HP HD Camera → Enable device (if disabled).
  4. If already enabled, choose Update driver → Search automatically.
  5. Restart your computer and test the camera.
Guide Placeholder: [Device Manager camera enable/update guide – coming soon]
Camera Driver Is Outdated or Missing
Problem: Missing or outdated drivers can prevent camera operation.
Solution:
  • Visit HP Support and search for HP EliteBook 830 G6.
  • Download and install the latest camera driver for your Windows version.
  • Restart the laptop and test the camera.
Guide Placeholder: [Camera driver update guide – coming soon]
4
Problem: Security settings in BIOS may disable the camera.
Solution:
  1. Restart the laptop and press Esc repeatedly at startup.
  2. Press F10 to open BIOS Setup.
  3. Go to Security → Device Security.
  4. Locate Integrated Camera and set it to Enabled.
  5. Save changes and exit BIOS.
  6. Test the camera in Windows.
Guide Placeholder: [BIOS camera enable guide – coming soon]
5
Problem: Hardware issues like a loose ribbon cable can stop the camera from working.
Solution:
  1. Power off the laptop and remove the bottom cover.
  2. Check the camera ribbon cable between the display and motherboard.
  3. Reseat the cable if loose.
  4. If the camera module is damaged, it may need replacement.
Replacement Part: HP HD Camera Module (Part # L13868-001)
Guide Placeholder: [Camera module replacement guide – coming soon]
6
Problem: Physical impact or liquid damage can permanently break the camera.
Solution:
  • Replace the integrated camera using the HP Maintenance and Service Guide.
  • If under warranty, contact HP Support for repair or replacement.
Guide Placeholder: [Camera replacement service guide – coming soon]
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:10
Past 30 Days:68
All Time:443
