FixHub Power Station Overheating
Sandra Hiller
Last updated on
The FixHub Power Station grows hot during use, perhaps unnaturally so.
Causes
Solution:
When the power station is putting out a lot of current (power) the battery will grow warm. This is a natural property of batteries. To protect the battery from damage, the Power Station will throttle the power output, which should prevent dangerous levels of heat.
  • If the ambient temperature is high, the output may throttle sooner under heavy loads.
  • If the Power Station feels warm to the touch, disconnect any loads and let the station rest for some time so that it can cool down. A half-hour to an hour may be needed.
  • You may need to allow the unit to rest after charging, as charging also creates heat, which may affect the ability of the station to deliver power.
If the Power Station gets excessively hot to touch, or continues to overheat even when not being used excessively, contact support for assistance.
View statistics:
Past 24 Hours:
Past 7 Days:
5
Past 30 Days:
17
All Time:
102
