Dell XPS 13 7390 Laptop Will Not Connect To Wifi
If your Dell XPS 13 7390 is failing to connect to a Wi-Fi near you, follow these steps to fix your Wi-Fi issue.
Causes
The laptop may not connect if the Wi-Fi adapter is disabled in Windows or via a physical switch, so confirming it’s turned on is the first step.
  • Check the taskbar for the Airplane Mode icon.
  • If it’s enabled, turn it off.
  • Open Settings → Network & Internet → Airplane mode to toggle it.
  • Ensure Wi-Fi is switched On under the same settings menu.
2
Temporary network or software glitches can prevent connection. Restarting your Dell XPS 13 7390 and router can resolve these issues.
  • Power off your Dell XPS 13 7390.
  • Unplug your router and modem for 30 seconds.
  • Plug them back in, wait for all lights to stabilize, then turn on your Dell XPS 13 7390 and reconnect to Wi-Fi.
3
Saved network profiles can become corrupted or outdated, so removing and re-adding the network can refresh the connection settings.
  • Go to Settings → Network & Internet → Wi-Fi → Manage known networks.
  • Select your Wi-Fi network and click Forget.
  • Reconnect by selecting your network again and entering your Wi-Fi password.
4
Outdated or corrupted drivers can block the Wi-Fi adapter from working properly, so updating or reinstalling drivers can restore connectivity.
  • Open Device Manager Network adapters.
    Right-click your Wi-Fi adapter (e.g., Intel Wireless-AC or Killer adapter) and select Update driver.
  • If that doesn’t work, select Uninstall device, reboot, and let Windows reinstall it automatically.
  • You can also download the latest driver from Dell’s Support page.
5
Windows’ built-in tools can detect and fix software or adapter problems that are preventing the laptop from connecting.
  • Open Settings → Network & Internet → Status.
  • Click Network Troubleshooter and follow the on-screen prompts to automatically detect issues.
  • If the problem persists, open Control Panel → Network and Sharing Center → Troubleshoot problems.
  • Run Internet Connections and Network Adapter troubleshooters to identify software or driver errors.
  • Restart your laptop once the diagnostics complete and test the Wi-Fi connection again.
6
If your Dell XPS 13 7390 still refuses to connect after software fixes, the internal Wi-Fi card might be the culprit. Over time, it can become damaged or fail.
  • Open the back cover (see Dell’s official service manual).
    Ensure the Wi-Fi card is firmly seated in its slot.
  • If it still doesn’t work, consider replacing the Wi-Fi card.
Resources
https://www.dell.com/support/product-det...
https://www.dell.com/support/manuals/en-...
View statistics:
Past 24 Hours:0
Past 7 Days:5
Past 30 Days:36
All Time:100
