Causes
Overfilling the SSD with large files and media can cause a rapid decrease in storage and performance. The laptop needs a certain amount of free storage to run its background internal operations. If it does not have the required free storage, the laptop's ability to refresh and open new content can be significantly affected, causing slower times and lag. To free up space, move large files to an external cloud, delete any unnecessary files or apps, empty the recycling bin, and consider upgrading to a larger SSD. To upgrade your SSD, follow these step-by-step instructions on iFixit's Dell 5320 2-in-1 Latitude SSD Replacement Guide official page.
- 10 minutesModerate
If your laptop is set on a thick rug/carpet, its vents might be blocked and unable to ventilate the internals. Start by changing the surface where your laptop is located. Next, check for dirt, gunk, or other foreign objects that might be stuck or stuffed into the laptop's vents or fans. In case of a damaged fan, you may need to take the laptop apart and install a new fan. Follow iFixit's Dell Latitude 5320 2-in-1 Fan Replacement Guide official page for step-by-step instructions.
- 10 - 15 minutesModerate
Check that your laptop software is up to date. Software updates can bring improved background refresh times and bug fixes. Updates are constantly changing how your laptop deals with daily use, and they provide improved optimization. If your laptop does not receive the most recent updates, other applications and services may be incompatible with your laptop's older software, and this can cause glitches and hinder the laptop's ability to run these services.
Describe your problem in your own words
