Dell Chromebook 13 3380 Speakers Produce Distorted Sound
If the speakers in your Dell Chromebook 13 3380 laptop produce distorted sound, follow this page for possible solutions.
Causes
A loose or partially detached speaker cable can cause distorted or intermittent audio. Solution:
1. Power off the Chromebook and disconnect the charger.
2. Remove the bottom cover using a Phillips #0 screwdriver.
3. Locate the speaker cable near the battery and motherboard.
4. Gently disconnect and reseat the cable, ensuring it clicks securely into place.
5. Reassemble and test the sound. If the distortion persists, inspect the cable for fraying or burn marks, and replace it if damaged.
2
Over time, the speaker cones can tear or degrade, especially if the Chromebook has been dropped or exposed to moisture.
Solution: Replace the left and right speaker modules using the official Dell Chromebook 13 3380 Service Manual. Follow the “Speaker Removal and Installation” section for step-by-step instructions. Replacement speaker sets can be purchased through Dell Parts or verified online suppliers.
3
Distortion can also come from software conflicts or outdated audio drivers. Solution:
1. Restart the Chromebook and update ChromeOS.
2. Reset audio settings: open chrome://flags, restore defaults, and reboot.
3. If distortion occurs only with certain apps, reinstall or update those apps.
4. Test audio with headphones; if it sounds fine, the issue is likely hardware-related.
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:6
Past 30 Days:36
All Time:390
