Shop the Holiday Gift Guide
Won't Heat Up
BellaRita and 1 contributor
Last updated on Causes
- Make sure that the curler is plugged into an outlet that works. Try a different socket to rule out external power problems.
- If your curler has a power or heating indicator light, confirm whether it turns on.
- Try giving the curler a few minutes to heat up. If it remains completely cool, the heating element may have failed.
- Look for burn marks, melting, or odd smells—signs the heating element may be damaged.
- With caution move the cord and handle while the device is on. If the heater intermittently turns on/off, loose or damaged wiring is likely.
- look for frayed, bent, or exposed wires along the power cord which can interrupt power to the heating unit.
- A loose or wobbly plug may prevent proper electricity flow.
- Faulty wiring can pose a fire or shock hazard. Unplug immediately if you suspect wiring issues.
- Heater wiring issues often require internal repair or full product replacement. Reach out to the brand’s customer service for next steps.
Related Problems
Bed Head Curlipops
2 problems · View all
Describe your problem in your own words
View statistics:
Past 24 Hours:3
Past 7 Days:11
Past 30 Days:55
All Time:233
