Introduction
If your Asus L410MA-MH09-CA turns off whenever it’s unplugged, the battery likely isn’t holding a charge. You should first be sure to check that your AC adapter is plugged into the wall, and that the outlet you’re utilizing is in working condition. If these are not the cause, then the battery or charger’s connection to your battery might be. Follow the steps below to diagnose the issue.
Causes
The battery may need to just be physically reset with a quick discharge of the power.
- Shut down your Asus completely. Be sure to remove all external devices.
- Unplug it from the charger, and hold the power button down for 15 seconds to discharge any residual power.
- Wait for five or more minutes before plugging the computer back in. Allow the computer to charge fully before unplugging to see if the problem has been resolved.
Many ASUS devices have built in optional settings to preserve the life of the battery. This step is to ensure that you’re able to access the full capacity of the battery.
- You’ll need to open the MyASUS program (start menu + search MyASUS), and navigate to Settings > Battery Care Mode
- Enable Battery Care Mode and set the recommended battery settings. It should pop up with the option to adjust the capacity usage.
- Make sure to switch it to 100%, otherwise the device may shut down at different recommended battery levels.
Describe your problem in your own words
View statistics:
Past 24 Hours:1
Past 7 Days:10
Past 30 Days:33
All Time:678
