Anker Soundcore Q20i Won’t Charge
If your Anker Soundcore Q20i doesn't power on and is unresponsive when you press the power button use this troubleshooting guide to help diagnose why.
Causes
Lithium-ion batteries include a protection circuit that disconnects the cell when voltage drops too low (~2.5–3.0 V). In this state, the device cannot power on until the battery is brought back above the threshold via charging.
  • Charge with a verified cable and 5 V USB source for ≥1 hour
  • Try a different cable and adapter
  • Inspect/clean charging port
  • If still no LED → internal hardware failure → replacement required
2
The device requires a minimum voltage to initialize internal logic. A degraded battery may accept charge but collapse under load when power-on is attempted.
  • Charge fully (2–3 hours)
  • Attempt power-on while plugged in
  • If failure persists → battery replacement or unit replacement
3
When power is applied, the system draws current. If the battery cannot supply sufficient current, voltage drops instantly, triggering shutdown.
  • Full charge cycle
  • Test with different charger
  • If repeatable → battery failure → replacement
4
The power button is a momentary switch that signals the microcontroller. Mechanical failure prevents the signal from reaching the control logic.
  • Inspect button for sticking or lack of tactile response
  • Clean around button
  • Apply firm press for 3–5 seconds
  • If no response → hardware repair required
5
The system operates from external power, but the battery cannot store or supply energy once disconnected.
  • Replace battery (if serviceable)
  • Otherwise replace unit
6
Microcontroller may enter a non-responsive state due to transient faults or power irregularities.
  • Perform hardware reset: hold Power + Volume Up (or Down) while connected to charger (~5–10 s)
  • Retry normal operation
Describe your problem in your own words
View statistics:
Past 24 Hours:5
Past 7 Days:43
Past 30 Days:135
All Time:495
