Tools Featured in this Teardown
Introduction
The new iPad Pro 11” sports narrower bezels, curvy LCD corners, and cutting edge silicon. This is apparently the iPad Apple dreamed about building from the very beginning, but what we dream about is a device that is easy to repair. Will this iPad fulfill both dreams, or will ours be left in the pipe? There’s only one way to tell—with a teardown!
Catch our Tweets, or drift through our Facebook and Instagram pages to keep up with the latest Teardown news!
Let's take a look at what sets this Pro iPad apart from its amateur peers:
Fully laminated, 11", LED-backlit, Oxide TFT Liquid Retina display with 2388 × 1668 resolution (264 ppi), featuring ProMotion Technology
Octa-core Apple A12X Bionic custom processor, with M12 motion coprocessor and integrated 7-core GPU
12 MP rear camera with 4K video recording at 60 fps, and 7 MP TrueDepth camera with 1080p video
Self-balancing, four-speaker audio
Face ID, five microphones, ambient light sensor, accelerometer, barometer, and 3-axis gyro
802.11a/b/g/n/ac dual band MIMO Wi-Fi + Bluetooth 5.0
64 GB, 256 GB, 512 GB, or 1 TB of on-board storage
With each passing year, Apple seemingly gets closer to realizing its dream of selling a blank slab of glass with its logo on the back.
It's a good thing we've got X-rays on tap from Creative Electron, or this would just look like a black rectangle.
As always, the darkest areas in the X-ray image represent dense materials that absorb more X-rays—usually magnets, such as those used in speakers and for clip-on accessories.
We're seeing considerably more of those than usual here.
Visual inspection time. Above the newly repositioned Smart Connector, we have a new model number: A1980.
Compared with its 10.5" predecessor, it looks about the same, and the lost .2 mm are hard to spot due to the squared-off edges.
Not that we mind at all—it actually reminds us of some of the iPad's more repairable competitors.
Final notes before we dive in: no headphone jack ☹, USB-C port (non-Thunderbolt) in place of Lightning, and a long dark oval to charge the new Pencil.
We loved the experience of cutting through all the glue to open our first iPad, and it has never gotten old.
It helps to be practiced at this, but these extra-thin bezels make it even a bit more harrowing than usual. Heat, carve, hold your breath, and hope nothing breaks.
On the plus side, the display's ribbon cables are a safe distance from the bezels—but they're also spread out in a way that makes display removal really awkward.
Actually on the left side of the display there are some sables that are quite close to the edge. DIYers beware!
Those cables aren't safe quite yet, as we're forced to lay the display at a weird angle and hopefully not damage anything while we disconnect them.
We put our Phillips driver to work releasing both cable connectors.
Now we see what those X-rays were trying to show us! One thing that immediately stands out is the iPad's quartet of speakers.
Is there a reason for empty space in the body of the iPad? Prevent interference or damage from the wireless charging unit?
The space is reserved for Display cable/PCB. You can refer to the X-Ray photos and the screen assembly
What is the name of the flex cable that was disconnected from the logic board after removing the protective plate at the top of the screen? The flex cable seems to have a microphone and a few sensors. On the repair I am working on the customer has ripped one of the sensors and it needs to be replaced but I cannot find a replacement.
I may have figured it out, but can’t find a replacement part anywhere at this time. I believe the flex contains the Ambient Light Sensor, Flood illuminator, Dot projector.
Does anyone know where they have seen this part for purchasing?
Hi Brandon,
This part is difficult to source, because it is inherently paired to the T2 security chip—you can’t restore functionality with a replacement part unless you have access to Apple’s special software.
This question may have been answered already - maybe I missed it - there is a flex sensor cable at the top of the display - each end of the cable has some kind of sensor that fits into a notched area at the top of the iPad case. It also has other components that fit between the cameras and dot detector. Does this cable have anything to do with Face ID?
Here's the new Liquid Retina display—scaled up from when we first saw it, and packing the same awesome 120 Hz refresh rate we saw on the last iPad Pro.
The fancy new display brings some chips along with it too:
Parade Technologies DP825 timing controller (the same one we saw on the iPad Pro 10.5”)
Texas Instruments TPS65158 (maybe a variation of the TPS65168 LCD Bias IC)
Renesas (formerly Intersil) ISL24833A 18-Ch. TFT-LCD reference voltage generator w/ integrated EEPROM (likely)
Is this the reason why the left side of the ipad is warmer than all the device?
i cant find this specific screen anywhere
Anxious for our first glimpse of that A12X
boxchip, we peel away the logic board cover next. -
Yuck—as always, the board is secured with adhesive, and it's made even fussier by the speakers, which block almost all prying access.
But we're impatient, and soon victorious. The logic board triumphantly emerges from the canyon betwixt the battery cells.
After all that, we're rewarded with some silicon:
Apple APL1083 A12X Bionic SoC
Toshiba TSB3247M61710TWNA1 flash storage (64 GB total)
2x Micron MT53D256M64D4KA-046 XT:B SDRAM (4 GB total)
NXP 100VB27 (SN100V) NFC controller
Apple / USI 339S00551 Wi-Fi / Bluetooth module
2x Broadcom BCM15900B0KWFBG touch screen controller
Texas Instruments CD3215C00 USB-C power controller
Looks like there's is a reserved space for second nand storage chip. I wonder if in future storage updates would be possible?
The space is likely to be filled if you bought the higher capacity iPad Pro option. This is the lowest capacity option, so there is a free pad.
More interesting is that the DRAM looks like it’s mounted on the same substrate as the A12X (ie not directly on the PCB like earlier iPads), so slightly closer to the PoP of iPhones. Is the substrate Si, or something else with lower capacitance than PCB?
It is not PoP package(Package-on-Package) . From the photo of A12X, it should not be PoP package(processor is next to two memory chips). Is that TSMC’s InFo or CoWos package technology?
JJ Wu -
Yes, that substrate is super-interesting. We need benchmarks comparing RAM bandwidth between this and the prior-gen iPads. What’s next for Apple … HBM?
HBM can provide higher BW. But, from power consumption, most likely, it can not be. LPDDR4x can provide lower power consumption menory solution for mobile devices, such as iPad.
JJ Wu -
So for the 6GB of RAM in the 1TB version, it is likely there is 1x4GB and 1x2GB DRAM chips, or might Apple have actually put 8GB of RAM, but only expose 6GB for user apps ?
perhaps the extra 2GB would used by the storage controller so it can manage the extra 512GB of storage ?
Any plans to tear down the 1TB version ?
I wonder what’s the minimum storage option that will start having a second NAND chip (assuming that empty space will indeed be covered with a second NAND chip in other size options).
I believe that TI’s CD3215C00 is a USB-3.1 redriver.
What are the dimensions of this board?
Does anyone know which Tristar chip this model uses?
These chips can't be contained to just one step, so here are some more:
STMicroelectronics STB601A0 power management (likely)
Apple 343S00252-A0 power management (likely)
Apple 343S00257-A0 power management (likely)
Apple 343S00248-A0 power management (likely)
Texas Instruments 343S00235 charger IC (likely)
Diodes Incorporated PI3DPX1203 DisplayPort 1.3 4-lane linear re-driver
NXP Semiconductor CBTL610 DisplayPort multiplexer (likely)
Pretty sure the last one is a Pericom / Diodes Incorporated PI3DPX1205A USB 3.1 / DisplayPort 1.4 Alternate Mode 10 Gbps Type-C Active Mux / Linear Re-driver (or something similar): https://www.diodes.com/products/connecti...
Main PCB IC Identification, Continued:
Winbond W25Q80DV 8 Mb Serial NOR Flash
ON Semiconductor FUSB301A USB Type-C Controller (Likely)
Analog Devices ADAU7002 Stereo Audio Converter
Maxim Integrated MAX98357A 3.2 W Mono Class D Audio Amplifier
Texas Instruments TPD6S300A USB Type-C Port Protector
Texas Instruments TPS61230A 6 A Step-Up Converter
Texas Instruments TPS61178 10 A Synchronous Boost Converter
Battery time! We were not fans of last year's iPads, which skipped out on the stretch-release battery tabs.
This year, pull tabs are back in style—six U-shaped strips this time! Each strip has two tabs, giving fixers a second chance should one of them break. Neat!
But the smooth stops there. A huge patch of supergoop runs all the way down the left side. Sigh. Time to break out the pry tools.
We were left speechless. Why would Apple do this? We could only hypothesize that the adhesive is there for "rigidity reinforcement".
This iPad's powered by a 7812 mAh battery running at 3.77 V, for 29.45 Wh—a slight downgrade from the 30.8 Wh pack in the 10.5" iPad Pro, and a lot smaller than the most recent Microsoft Surface Pro's 45 Wh battery.
“We were left speechless. Why would Apple do this?”
Those speakers pack a load of low bass.
component vibrations are out.
That is definitely a possibility. However, we were confused as to why Apple would choose to use stretch adhesives in conjunction with it, and why it’s only one one side of the battery…the left side. We found a similar band of super-adhesive in the same location on the new 2018 iPad Pro 12.9”.
Very weird. Is it possible that Apple repair techs use an adhesive dissolving solution? Would make the repair “easy” for them while keeping the batteries solidly in place.
En la traduccion al castellano, en el parrafo que dice “Nos hemos quedado sin palabras. ¿Por Apple aria esto?…” daña la vista el “aria” sin h :-) Por favor corregirlo cuando podáis ;-)
¡Hola Ruben! Te invitamos a que nos ayudes a traducir las guías al español. Puedes ser un voluntario más y ganar puntos de reputación. Tenemos muchos voluntarios, pero nos vendría genial tener más gente que encuentre errores de ortografía o que ayude con la traducción de las muchísimas guías que tenemos aquí. Saludos, y gracias por tu buen ojo.
Next up, making its debut in the iPad: Face ID.
More specifically, this is the same basic hardware we've seen since iPhone X—IR dot projector, selfie camera, and IR camera—but in a slightly modified form factor.
While we're at it, we fish out the rear camera—which Apple says brings the same performance as the camera from the previous iPads, while being re-engineered for more thinness.
With the loss of OIS, and still a huge camera bump, this design seems shot through with compromise.
The IR dot projector IS the flood illuminator.
No it isn’t. Those are two separate components, just like on iPhone.
The IR flood illuminator sits right between the FaceTime- and IR-camera and is probably part of the front assembly, while the IR dot projector is way off to the right of the FaceTime camera as seen above.
MrUNIMOG -
Let's remove those speakers, shall we?
That's easier said than tear-done. The housings are carved right into the aluminum case, and were clearly never meant to be removed. Digging them out takes a ton of heat and willpower.
The tweeters come out without a fight but the woofer drivers are pretty much toast—hope they're made of never-fail-ium!
Hiding within the speaker chamber; more magnets! If we had a nickel for every magnet in here, we could melt them all down and make a giant novelty nickel.
Any idea why so many magnets? That looks like 12 in the housing on the right side, but only one voice coil with the one large one in the middle. What are the 3x3 array on the left, and the 2x1 array on the right for?
Accesories. I suppose that’s because such a matrix allows a nearly perfect allignement with pencil/keyboard, thinking to a “flatter” magnetic field instead of a round big one
Next to come out is the Pencil charging board, with its copper charging coils attached.
While it's technically out, it's not without casualty...
Tiny capacitors and other board bits go flying in protest as we remove the shields. Are we sorry? No we're not.
What's this we see, hiding in the corner? It's an STMicroelectronics STM32L476JGY6 ARM Cortex MCU.
Texas Instruments TPS60151 5V charge pump
ON Semiconductor FPF1204UCX Load Switch
Those flying board bits are the Chinese spy chips trying to evade identification. Conspiracy theorists discuss…
Do you think it would be possible to "extend” the charging coil from outside so that pencil could be charged without removing from a case? I’m very unfamiliar with how coil charging works so this may be a totally stupid question. In the simplest terms I’m thinking of just a piece that fits on the outside of the ipad case where the pencil would go, and extends it about 5mm into the hole on most of the cases that are currently available.
Technically, that is possible, and one could even build it into a case. You could place something made of iron in a specific shape that would couple and extend the magnetic field out. Efficiency would drop based on how well it’s implemented though. But, this wouldn’t be necessary if the case material is thin.
Most likely! Please check this link for more details.
Can this piece be used sand alone without the rest of the iPad? I want to sit my pencil on a desk charging and not always drawing power from my already fragile battery ? life on my iPad. I was thinking maybe just ‘Aquire this part’ & make an external case for it.
where can we purchased this item. i have water damage board for this. pencil no work and not detected
What is magnetic sensor for smart cover?
Last to come out is the USB-C port—which unlike previous iPads, is fully modular.
This is a high-wear component, so the ability to replace it independently of the main board is a nice repair win.
It might not be a win for people who are heavily invested in Lightning, but our message to those people is: At least USB-C offers faster throughput in a standardized, non-proprietary form factor.
About the only things left in the chassis are a whole ton of
nickelsmagnets.
“At least USB-C offers faster throughput in a standardized, non-proprietary form factor.”
At least Lightening could configure itself to carry analogue audio at an adequate power level for headphones.
The Lightning spec has never allowed analog passthrough, to the best of my knowledge—it’s all digital. If it could carry an analog signal, you wouldn’t need a DAC embedded in the headphone dongle. USB-C headphones in general are definitely kind of a mess right now though.
“At least Lightening could configure itself to carry analogue audio at an adequate power level for headphones.”
Do you mean that this cannot? https://www.apple.com/shop/product/MU7E2...
Lightning plugs have all of their contacts exposed, and users inevitably touch them, depositing skin salts and oils that together with the electrical current over time causes corrosion of the plugs and the device’s internal contacts. USB-C ought to be much more reliable in the long term because users can’t casually touch any of the contacts. Lightning cables also have an extremely high failure rate at the point where the cable attaches to the connector, with broken conductors and/or insulators.
USB-C also can handle much higher current and much faster data rate than Lightning.
And USB-C allows for hard drives, Ethernet, monitors, DSLRs, CD/BluRay drives - if anyone uses them - CD seems basically dead - is BluRay on its way out too?
Just about. It’ll be replaced by SD’s or small SSD’s, which will likely be followed by holochrons.
I’m glad they decided to make the type c port modular, as an iPhone user who’s used to Lightning port robustness I’m never comfortable plugging in type C devices.
Type C’s snap feels quite similar to USB micro-B, which in my experience they don’t last long ( at year 2 they started getting loose, and at year 5 most of them has lost most the resistance if not all. In contrast I have never found an iPhone with loose lightning port.
Hi, I’m a newbie to self-repairs but basically my charging port or the “chip” that the local repairmen said may be damaged, can someone tell me what is that second part above the USB-C charging port? Oof, much gratitude and thanks.
Okay so technically there is one entry point, but we all know nothing's getting in through that tip.
With the tip removed, we go straight for the big guns. Bring out the ultrasonic blade!
When the dust settles, a metal rod emerges from the Apple-white plastic shell.
Looking around, we spot the new wireless charging getup, some magnets, a black sheath, and a wounded teardown engineer. ☹
We tried pairing the old Pencil to the new iPad by using a Lightning to USB-C connector, but the iPad refuses to acknowledge the old Pencil.
We honor the engineer’s sacrifice
how did he get cut? I thought iFixit was safe!
“She” actually =) I was wearing safety goggles, but unfortunately my hands weren’t wearing armor.
Is there a technical reason why the new pencil couldn’t be backward compatible to the first-gen iPad Pro? Or to allow for wireless charging on the old iPads, could Apple have made a thin smart-connector accessory that would get power from the smart connector and then have the necessary Qi-like charging coil to transmit to the ApplePen2. That would be a problem for the first gen non-Pro iPad, which doesn’t have a smart connector - but it could also have a lightning plug in the center.)
It seems that “buy the pencil now, upgrade to a new iPad pro later when you have the 2K to do so” marketing strategy might work. Though if you’re going to drop 2K on a new iPad, 0.12K for a new pencil really isn’t that much I guess.
A large black ribbon cable unfurls from around the Pencil body, revealing what looks like a capacitative grid!
Unfortunately, it's back to destruction from here—the Pencil's many welded steel layers put up quite a fight, and we're only able to reveal a few components.
Battery (even we don't want to tempt that little explosive)
Wireless charging coil
Alignment magnets
Broadcom BCM59358A0 wireless charging IC (likely)
Analog Devices 343S00250 Apple Pencil nib sensor controller (likely)
What is the gold piece at the end of the pen? My dog chewed mine off. Its still working ;)
I’m surprised the Apple IC (blue) doesn’t have “P2” on it (P for “pencil”).. How does the “tap” work - is it a tap of the pen tip on a surface, or a finger tap/squeeze on the barrel of the pencil itself? The capacitance grid looks like it’s separated into “square-like-areas” (9x6 it looks like). Could this be to allow for multi-touch on different places? Something like different brushes in a graphics app depending on where you held the pen? (Say holding it with index and thumb - close to the tip end for a writing tool, middle for something like a paintbrush , or the “erase” end for something like a “spray-paint” or dodge/burn brush).
Or (either as an Apple joke, or a third-party joke) use said hypothetical multi-touch capacity to turn the Apple Pencil into a kazoo/flute? (Or a Ressikan flute penny whistle for the Star Trek fans?). But that would need a separate tip or some device to pick up the signals and transmit them over a longer distance - or does the Apple Pencil use “normal range” Bluetooth?
Been wondering at the battery capacity of this thing. It seems to discharge much faster than the previous generation, but also charges much faster. I had a hopeful guess that maybe it was a capacitor and not lithium, increasing longevity and justifying the odd capacity quirks.
DNB Markets, DNB Bank ASA deeper and more brutal teardwon actually. There is a nRF52832 Bluetooth Low Energy chip from Nordic Semiconductor in there. Here is a ref from IHS. https://twitter.com/LeeRatliff/status/10...
Apple Pencil IC Identification, Continued:
Bosch Sensortec BMA456 3-axis accelerometer
Maxim Integrated MAX44284 current-sense amplifier
Maxim Integrated MAX4971 overvoltage protection controller
ON Semiconductor NCP161AFCS180T2G 450 mA LDO regulator
SiTime MEMS oscillator
Attempting u to _ charge - my apple pen on my apple watch charger -,- is this a bad idea?
This iPad Pro is no mo'—we've broken it down to its constituent parts!
It's hard to tell if this is a good Apple, or a bad one. There's a modular USB-C port and stretch-release battery adhesive, but it's still mostly glued together and a strip of tough conventional adhesive also secures the battery.
It looks like Apple is trying to change, but the voice on the other shoulder was a little louder than the repairability angel this time around. That said, with all of Apple's late 2018 products showing some improvement, we're hoping the repairability angel is gaining influence.
Can you highlight the magnet locations? Maybe tear down the keyboard or folio case? Interested to know where the focus of the magnetic contact are. Might help with future case designs.
For magnets, you can’t do much better than the X-ray image in Step 2.
- The USB-C port is modular and can be independently replaced.
- The lack of a physical home button eliminates a common failure point and may simplify repairs.
- The battery is secured with both easier-to-remove stretch-release tabs and conventional, non-removable adhesive.
- The LCD and front panel glass are fused together—simplifying the opening procedure, but increasing the cost of repair.
- Gobs of adhesive hold most everything in place, making all repairs more difficult.
Final Thoughts
Repairability Score
(10 is easiest to repair)
41 Comments
Just a question on how these 2-cell batteries work…
If I’m on 50% battery charge, will both “sides” be half-full or will one be completely depleted?
The 2 cells are connected in parallel so they both drain at the same rate.
With the 1TB model having 6GB, is that achieved with a higher capacity part or is there space for a third RAM chip?
As I noticed the ram is installed on chip, it is unlikely there will be enough space for a third one
So either the 1TB version uses two 3GB RAM chips (not sure this size exists), or the A12X on the 1TB version offers up the additional 2GB internally, or the flash controller contains 2GB RAM that somehow gets mapped into the OS (doubt this). I have the 1TB version and am just curious how this is implemented.
tskwara -
There were 3GB LPDDR4 RAM chip offered by Samsung and were used in the iPhone 8 Plus. Not sure if it will be the case of the iPad Pro, but 3GB RAM did exist.
24 Gb (3 GB) LPDDR4X packages are definitely a thing, so most likely just two of those.
It said that there is 4GB in total
Concerning this picture from step 5: https://d3nevzfk7ii3be.cloudfront.net/ig...
Is there really so much unused/empty space on the left side of the enclosure or am I missing something here?
And could you provide the battery ratings for Apple Pencil 2?
If you look at the XRay photo and the screen assembly, you will find that these space are reserved for display cables.
Indeed, the display panel’s logic board occupies this space. In the last iPad Pro teardown, however, no extra space was needed.
Simon -
Well, in the iPad Pro 10.5 inch model this empty space is located on the bottom side of the enclosure.
Simon -
My guess is that it’s a loudspeaker enclosure, among other things it helps make the sound more punchy and less tinny from the 4 woofers
How did they get all those parts into the pencil?
Magic, Elves and Fairies at the FoxConn factory. All of the above have small hands! ;-)
Custom engineered enveloping and machining.
An apple shop representative in Miami, told me that, the 1tb model iPad Pro is on par with this you opened up and all the others, about the ram, so it is just 4gb.
she said the 6gb ram on the 1tb iPad Pro is only a rumor.
Has anyone evidence of this 6gb ram? If I can be sure about it I would buy that size of memory..
This firstly comes from Xcode which implies that there is a new iDevice with 6GB RAM, and it is very likely to be the new iPad Pro, as none of those iPhones get 6GB RAM.
GeekBench indicates that there are 4 models of iPad Pros has 6GB Memory: iPad8,2,iPad8,4,iPad8,6 and iPad8,8.
All of those models have “x“ in the Mother Board model name, and those names somehow connect from each other, for example: “J317xAP“ for iPad8,2; “J318xAP“ for iPad8,4; etc, and iPad8,8 got “J321xAP”.
In contrast, the ones with 4GB RAM do not have “x” in their Motherboard name. For example, iPad8,7 got “J321AP“, indicates that model is similar to iPad8,8, but the latter is an “enhanced x“ version.
The iPad pro 1TB model has 6GB of ram, but this is to help with the extra storage, no performance gains sadly.
Space -
What type of aluminium is the iPad Pro made from?
What about the extra Holes in this new iPad? There is one on the display front, right next to the FaceID Camera. And there is one on the left side in the middle. First i thought it is the SIM tray removal hole… but: i am using the WiFi model…
Microphones. The iPad has multiple mics to help with noice cancellation and for Hey Siri functionality.
djfriar -
The ability of the Face ID to work in both orientations is hw- or sw-based? Thanks.
please uninstall all Magnets! Over 100.. new wight ? Nothing is netter than a lightweight Tablet
If you compare the 11-inch to the 10.5 inch last year, the wifi model is actually lighter.
This also applies to the 12.9 vs 12.9
So those magnets did not make the tablet heavier. If you are comparing the 12.9 inch this year with 10.5 inch last year, of cause it is heavier
Can anyone give a definitive answer as to if the 1tb version has 6gb ram please.
I'm a total non tech so forgive my lack of tech
But I've read many reviews and learnt a little
Even one of the messages above refers to Xcode 'implies'
Still nothing definitive
Others say the geekbench tests don't prove 6gb but suggest
Got thru to Apple managers of both CPU and IOS department
- unbelievably they don't have a clue!
…and even they agreed Apple should publicise their specs
We all get why they don't but still…
Still no certainty after over 3 weeks of rumours.
Plus much debate over whether it'll make any difference for any but the uber power users
So probably only solution is a tear down of a 1tb
Have I missed this?
Even a hi tech apple store guy I know well said ifixit had a tear down to prove the 6gb
..but all I can't find this.
Seems like the only definitive answer is a tear down
Is this going to happen guys?
Thanks
Why do they have so many magnets in the speakers, I always thought a speaker needed one magnet to drive it’s respec driver?
what is the frame part made of, looks not strong enough to support the whole structure and will cause bending over time.
BE WARNED! the replacement screen does NOT come with the ambient light sensor attached. You will need to use your old one and unless you attach it perfectly (the sensors are held in place by hot glue), face ID will no longer work. If I were to do the repair again, I would spend the extra $100 and have Apple replace it.
Que son los flex que están incluidos en la pantalla? Dos inferiores y uno superior. Tengo un ipad a1980 con todos los flex cortados al separar la pantalla y no encuentro información para identificarlos.
The screen on my iPad is toast (tends to happen when you leave it on the roof of your car and drive down the interstate). I’m looking at purchasing a new screen from here, but have one question on it. The screen as shown in the teardown has connectors both top and bottom of the display, but the screen available for purchase only shows the bottom set of connectors. Is there a different assembly at the top of the display for something else, perhaps mic or ambient light sensor that I need to acquire?
Hi David,
You are right—those look like the ambient light sensors and mics. Try to detach them from your original display to transfer to your replacement screen. You may need to use some heat. Pry carefully with a non-metal tool.
If you replace the display with the one on Ifixit, does 120hz ProMotion go away when you replace the screen?
Gracias, un saludo desde Colombia, Que hay que hacer para montar una franquicia en mi país ?
Me dedico a Reparar cargadores de Mac, y computadores, cada vez me llegan mas clientes para que les alquile las herramientas y les diga cómo hacerlo, en su mayoría son estudiantes, o profesionales jóvenes que quieren relajarse contribuyendo al uso razonable, a reutilizar equipos desechados.
Hi,
nachdem mein Dipsplay defekt war und bei der demontage auch noch da flexkabel der FaceID gerissen war, musste ich mir ein neues einetzen.
Dennoch meldet das ipad nach dem Ersetzen der zwei Teile das die FaceID nicht funktioniert und der Stromverbauch ist enorm auffällig nach Oben gegangen. Kann es sein, das diese Flex mit Sensoren und cam, nicht ersetzt werden können (sollen)? Daher der hohe Stromverbauch
Gruß Matthias
