Before you begin, position the computer face down, resting the computer on an ESD mat or other soft surface.
Position the computer face down, resting the CRT on an ESD mat or other soft surface.
With a flathead screwdriver or coin, turn the colored latch counterclockwise on the access door.
Pull the access door down to open.
Push down on the plastic tabs to release the SDRAM module(s).
Carefully lift the SDRAM from the slot.
With a flathead screwdriver or coin, turn the colored latch to open the access door. The antenna and AirPortCard will be visible when you open the access door.
Remove the AirPort Card by lifting the card straight up and out of the card guides and connector.
Disconnect the antenna from the small hole AirPort Card.
Position the computer upside down, resting the computer on an ESD mat or other soft surface and remove the bottom housing, EMI cover, and SDRAM.
Remove the four screws connecting the CD/HD drive carrier to the the metal chassis (also known as the divider panel).
Disconnect the following cables from the back of the CD/HD carrier: hard drive power cable, hard drive data cable, CD-ROM/DVD-ROM data cable, logic board cable connector.
Remove the six screws on the logic board and five screws on the downconverter board.
Gently lift the downconverter board and logic board out of the computer.
Using a flathead screwdriver, pry the plastic rivet off the board. Put the top half of the rivet back into the bottom half so it doesn’t get lost.
One Comment
Thank you so much for having this page. I just got this family model (free). This page helped me get to the hard drive to reinstall the OS on a G3. Then back to this model. The CD does not read disks. So I had to move drives around just to install for the Blueberry. Again THANK YOU SO MUCH :)
P.S.
I hate making an account just to comment. &&^&^$^ ass holes.
