This teardown is not a repair guide. To repair your iControl Networks Piper, use our service manual.
  1. iControl Networks Piper Teardown, Cracking Open The Case: step 1, image 1 of 1
    • Piper is held together with four "security Philips" screws located in the battery case. Each screw has a post in the middle, meant to foil use of a standard screwdriver. However....
    • If you don't have the right bit, just use a large #2 philips head screwdriver: the bit won't go deep enough to get tangled up in the security feature.
    • Once the screws are out use a plastic spludger to pry open four plastic clips holding the shell together.
  2. iControl Networks Piper Teardown, What's Inside: step 2, image 1 of 3 iControl Networks Piper Teardown, What's Inside: step 2, image 2 of 3 iControl Networks Piper Teardown, What's Inside: step 2, image 3 of 3
    • Piper is dominated by a large speaker, and a Mallory PS-953Q security horn. It's loud. The CPU is a Texas Instruments TMS320DM365 media processor with a ZW0301 based Z-Wave module.
    • Piper uses two tiny antennas, one for Z-Wave one for WiFi.
    • That's it... a pretty simple layout.
Bryce Nesbitt
1,214 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 2,355
