Fix Your Stuff
Right to Repair
Parts & Tools
Help
Editing Step 8 —
Step Type:
Drag to rearrange
Once slide is removed, you got access to LCD and touch assembly. Easily remove the small flexcable from touch to LCD and take off LCD.
If you've got a new LCD assembly, probably no speaker is part of it. In that case don't forget to remove it from the defective assembly (see on the far left) and put it in the new assembly. It is simply mounted with adhesive.
