Help
Editing Step 6 —
Step Type:
Drag to rearrange
Time to remove the small logic board. This L shaped piece is held in place with a little adhesive and a few little plastic clips.
By applying a little pressure to the larger black clip near the power button area will pretty much free it enough to begin prying it out.
Before moving on we need to free the adhesive which holds the volume button assembly in place. Just slide something thin in along the backside of the volume assembly to free the adhesive. Now we can move on.
When you get close to the volume ribbon cable leave your pry tool under the logic board and grab some tweezers to pick the volume assembly out of its slot.
After the volume assembly is out, finish prying out the small logic board.
