Help
Editing Step 4 —
Notice: You are editing a prerequisite guide. Any changes you make will affect all 2 guides that include this step.
Step Type:
Drag to rearrange
Your next step is to remove the five screws holding down the motherboard. Use the PH1 philips screwdriver.
Once you have removed the five screws you may lift the motherboard off of the front case.
At this point you may also remove the dial pad. It simply lifts off.
You may also remove the speaker if needed by unscrewing the two screws using the PH1 philips screwdriver.
The whole phone is now disassembled at this point.
