Fix Your Stuff
Right to Repair
Store
Help
Editing Step 6 —
Notice: You are editing a prerequisite guide. Any changes you make will affect all 2 guides that include this step.
Step Type:
Drag to rearrange
Always pull wires from their plastic ends, not their cables, to avoid wire damage.
Gently remove the three grey wires from the metal tabs.
Insert the tip of the plastic opening tool into the bottom left corner of the panel.
Keeping its tip under the top panel, slide the plastic opening tool around the panel until the panel is completely loose.
Gently lift off the top metal panel.
